Hesitation when accelerating.
If you're still around, I wouldn't mind a resolution to this; my new plugs also foul quickly, the usual suspects all appear good or have been serviced, and I'm chasing intermittent hesitation issues thanks
Check the TPS plug wires. Mine were really bad and causing some issues. I got new plug from 944online and made some pigtails and replaced the old plug. Also, my multimeter was not working properly. Got a new one with auto range. My TPS had open spot near WOT and back down close to idle the my old meter did see for whatever reason. Replaced that with a spare that test good.
Digital multimeters are not good for testing the TPS or AFM. An ocilicope will thou(kinda pricey). You want to use an analog ohm meter to test potentiometers. The digital meters just aren’t fast enough to react and display a bad potentiometer.
