Ported Turbo?
Apparently this is real popular around the DSM crowd. They say it gives the turbo quicker spool and a few more HP. Anyone done this to a KKK26?
Bannana Shine
I think you've got it mixed up. As far as I know, porting slows down spool time and reduces peak output a bit, in order to move the surge line to the left - that is, make able to achieve lower flow rates at a given RPM without surging.
I don't really see the point of porting the turbo as long as you have a diverter valve.
Not sure what they mean. Thats part of my post too. I keep reading about people selling these ported turbos for sale. I ask what it does and they say a few more HP and quicker spool up. I thought maybe we could port the inlet of the K26 a bit to get some more power maybe.
I know what porting the compressor housing is and what it does, I have also heard of porting the turbine housing, but this only serves to reduce backpressure (improves spool time, but reduces the maximum turbine speed atainable...)
which is why I asked for more details.. IMHO porting the turbine housing on the K26-6 wont provide a real world benefit, as it is not backpressure limitted in my oppinion... it is size and terminal speed limited..
porting an oversized turbo may reduce spool time, but again, only if the limiting factor on the rubo is backpressure... I.E. a small turbine with a larger compressor wheel... which just isn't the case on our older turbos.. now if it were a DBB center section, -6 turbine section with a 27 or larger compressor wheel porting the turbine housing may yield some spool gains at the cost of turbine efficiency..
Lots to considder, especially when there are more modern turbos available to provide much better efficiency curves... but those come at a financial cost intollerable to many of the users of our little old cars (talking about turbos costing well above 1K each)..
neither has much to do with the diverter valve...
HP claims on a ported turbo are much like HP claims of a chip set... they are bench racing numbers.. as the seat of the pants "feel" is different from the actuall demonstrated performance on a dyno...
Stock 14B Mitsu turbos have internal wastegates and an appalling line-of-flow from the turbine wheel out. You hog the crap out of the outlet and cut back to the wastegate divider wall so it can breathe. If you try to push a stock one too hard it overworks the wastegate--the flow past it on the turbine side pushes it shut! A couple hours' worth with the Dremel and you'll have a Talon in the 12's. It's crazy easy to make power with one.
Since we don't have an internal wastegate it's not a problem.
Bannana Shine
Stock 14G Mitsu turbos have internal wastegates and an appalling line-of-flow from the turbine wheel out. You hog the crap out of the outlet and cut back to the wastegate divider wall so it can breathe. If you try to push a stock one too hard it overworks the wastegate--the flow past it on the turbine side pushes it shut! A couple hours' worth with the Dremel and you'll have a Talon in the 12's. It's crazy easy to make power with one.
porting or extrude honing housings is only worth doin if you have bigger wheels and realy cant fit bigger housings or don't want to as your cheating trying to look stock...
and anyone who would do a mod to "reduce surge" simply doesn't understand what surge is...
give me an example of surge on a road car
your posts reference the compressor side...the 14B needs a ton more help on the turbine side.
here are a pair of links so you can see the brilliant mitsu design for yourself:
http://www.vfaq.com/mods/porting-turbo.html
http://www.vfaq.com/mods/porting-O2.html
you can see how they go together to make a real clusterF of the exhaust flow. Also, the wastegate BARELY opens, so boost creep is a major problem.
If your looking for a few cheap horses like i was, you can try just polishing the inside of the compressor housing. I did this on my K26-8 and it made a world of difference, especially through the upper rpm. If you look on the inside of your comp housing outlet, you will see a ridge that looks to be a stop for maybe a boost pipe that slides inside the housing instead of clamping on the outside like the 951, thats something i also sanded out. Just my 2 cents
i think the thread was about the anti surge slot/groove/ports... i herd they can effectively fatten the map and it makes sense as they feed the secondary blades better . i still say surge is almost never on most thing perhaps ina an on/off throttle drive ...
i am all for polishing stuff you can get to as it cost nothing and probably does a little
