Leaking master cylinder?
I am getting brake/clutch fluid dripping into the foot well when I press the clutch pedal. I haven't taken anything apart yet and was wondering what was most likely causing this? Your thoughts please.
Clutch master cylinder more than likely. I recommend getting a slave cylinder and new hose and blue feed line while you have it all apart... dont forget a motive power bleeder...
Im in the middle of all this myself (havent actually started on it, but is the primary reason why I took it off of the road and started all the other maintenance)
