Variable compression engine
http://www.new4stroke.com/
hmmm... interesting....
or even
http://www.sandersonengine.com/
If it's polish, you know it's gotta be good!
or even
They've probably spent millions designing that engine and I bet us regular people cannot afford to buy it so it cannot possibly be engineering involved
Saab actually presented a working variable compression engine in early 2000:
http://en.wikipedia.org/wiki/Saab_Va...ression_engine
Hi All,
http://fairdiesel.co.uk/products.htm
They are Poles, who skilled spy on the Porche
Regards Andrew
Regards Andrew
And in a measure of free time with my friends amateurs musicans in 1979
http://www.new4stroke.com/D1979.mp3
In my structure exceptionally it is easy to carry out such a changeable compression ratio. He is carrying out sie it behind the help very of straightforward device for the picture. And most important: this device is changing the compression ratio in all top hats of the given engine(even for example 16 cylinders).
It is very much cheap way, and simultaneous in the reliable way is carrying out all described higher virtues of the changeable compression ratio.
Engine new 4 stroke has changeable compressio ratio.
It's up to the angle of coupling with the main piston .
Graph some varations:
Regards Andrew
Looks like a really neat design... But a rebuild is gonna be quite something.... Rack gears, etc. Piston engines already confuse some people who are afraid of moving parts (rotary engine fanatics). Imagine this.
The hardest thing is to make a proper project, because, for example, to calculate the same displacement, it was necessary to use a computer, and it turned out that this structure has a variable compression ratio, which in combination with variable valve timing gives the angles not easy puzzle to solve ..
However, according to the motor execution of the project is much simpler.
Here is an example as flat block that has no flaws of the previous flat block of poped.
It can be cast as a single unit. It did not need the division on the block and head. Because the pistons can be put at the bottom and pistons going down..
Do not need a place in the head as the valve poped.
Andrew
I like this thread - some new tech I'd never seen before. It really excites me as an engineer!
The first one looks complicated - there's a lot of parts that can wear or fail. The new4stroke is pretty clever. I like it but I'd like to see how large that head will be, and how heavy. I like the idea of putting variocam tensioners on the timing belt though. And that Sanderson looks like the barrel engine taken to the next level... still very cool. I'd love to have a Y-6 or X-8 engine in my car, LOL!
Hopefully this engine will eventually make its way into a real world application, giving the word "engineering" all of its value
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
You guys do know that a turbo engine is basically just a variable compression pressure device?
In theory that is a much better solution – low compression pressure and less pumping loss when power is not needed and high compression pressure when required.
Professional Hoon
with the engines with the 2 extra pistons, lets say a 4 cyl plus the extra 2 pistons per cyl is 12. 4 of 3 different sized cylinders. okay now who would like to rebuild one.
Im not against it, looks cool. but after you hit that 200,000km (120,000miles) it will need a rebuild.
Aren't the Mercedes Kompressor engines basically the same design as these?
I don't think it's a terrible idea, but ...why bother? Spending all these R&D dollars on an outdated engine design so it can get another few MPG...big deal. Come up with something new!
