White plastic heater damper linkage clip repair?
So thanks to a tip by Brian Broderick in my other thread I may have found the cause of my always having heat condition. I checked under the dash and found that the white plastic heater damper linkage clip was broken.
Anyone have any tips for this?
Where’s a good place to pick these clips up?
![](http://i104.photobucket.com/albums/m190/turboculture/Heater1.jpg)
![](http://i104.photobucket.com/albums/m190/turboculture/Heater2.jpg)
You can pick up the clip pretty much at any part supplier. Pelican (http://www.pelicanparts.com/index.htm) is probably your best choice as they are in CA, so shipping to you should be quick.
944.572.314.00
944.572.314.00
As a quick fix before they arrive you can try to tie-wrap the rod to the little piece of white plastic that is left. I did that to my car 6 months ago and it's still holding. I have the pieces to fix it (...somewhere) but it has held.
