wanted to confirm question about adjustable fuel pressure reg.
Why would you want to do that?
Fuel pressure is maintained at a constant value by the FPR, but the pulsing of the injectors causes minor fluctuations in rail pressure. The damper acts as an accumulator to smooth out these pulses ensuring accurate fuel metering.
Yes, we keep a dampner. The dampner does just what it's name implies, it helps smooth out the pressure fluctuations in the fuel rail when the injectors fire.
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
The stock management system uses a batch fired set up - all the injectors open and close at the same time. This can cause a fluctuation in fuel pressure as the system goes from all closed to all open. The damper absorbs the sudden changes.
Stand alone systems running in full sequential do not need a damper and they are not required for a semi sequential but it is a good idea to include one to keep the fuel pressure as even as possible.
Basic Sponsor
968 does not use a damper. S2 does. Go figure! They are different injectors.
Mike or Dave Lindsey
www.lindseyracing.com
U.S. 1-877-943-3565
Other 1-405-947-0137
U.S. 1-877-943-3565
Drive-by provocation guy
Except for those going full rebuild or fuel system replacement, I don't know of many ever getting a new damper.
Is it something that should be replaced if old/stock?
Basic Sponsor
speaking of pulsations, i can really her my fuel pump when the car is at idle with 83lb injectors...tump tump tump tump tump tump tump.............
this is a new dampner as well...it killed my fuel pressure gauge too!
me too - I've killed 2 fuel pressure gauges since I put the 83#'rs in!!
The FPR is what controls the pressure in the system, but shouldn't have to exceed 3bar (44lbs) in the system...especially with 83# injectors (WHICH ARE F'ING HUGE!), so there should be no additional strain on the fuel pump.... can't imagine why it would sound different.... or why you would be going through gauges....
The needs of the engine are the same regardless if injector size anyway. Say you want 14.7:1 AFRs... if your engine is at idle, it will require the same amount of fuel that a car with 23# injectors would need at idle to achieve 14.7:1 AFR.
I am running 80# injectors in my NA right now ..... which are massively over kill (They are for my turbo build. Stock injectors were going south, so I upgraded to what I will need in the future) ... and my fuel pump sounds the same.
#80+ injectors are WAY overkill for a 951 anyway. I'm planning on 400+ RWHP on E-85 with a 2.8.... and I still will have tons of head room. Why are you guys running such big injectors?
Unless I have completely missed something, I don't understand why you're having the trouble you're having.
