CANASTER NEXT TO BATTERY
What is the canaster next to the battery. If you are looking at the engine it is to the right. It is a plastic canaster about the size of a cup with vacuum line going into it. What is its purpose. My is missing and the vacuum line is capped off.
Thanks John
Thanks John
Usually something described like that is a vacuum reservoir. I cannot picture exactly what you are describing off hand as I havent noticed it on mine yet..LOL. But from the description it does sound like a vacuum reservoir.
JBrown, yes that would be the vacuum cannister or vacuum reservoir. It holds a surplus of vacuum. I have not driven mine without it, but I believe if you run without it, you might lose power brakes, and other features that are vacuum operated/assisted, once the intake manifold becomes pressurized.
Likely only if you commonly fiddle with the HVAC controls while the engine is making positive boost pressure.
The diaphragm control valve in the coolant line to the heater core causes a lot of heater/temp problems.
That canister If I am not mistaken is connected via a connection T to the heater control valve
He would know better
Correct me if I'm wrong, but the only flaps that are vacuum controlled are for the fresh air intake in the HVAC system, the rest are all controlled by electric motors. Other than the heater control valve (which would default to open when not under vacuum) everything else is electric.
