Bling Porn " WARNING GRAPHIC"
At least you admit it. lol
#1, combustion doesn't take place in the header. Do you really think that all the heat travels out the exhaust without any temp effect on the block/head/cam tower?
#2, Feel free to reference Fourier heat equation and entropic properties. There are a lot of dynamics at play here, far more complex than what you make it sound like.
#3, the IC black paint dissipation of heat will be superior to the polished AL IC rejection of heat.
#4, this is all academic, in the real world, I'd expect it to have a minimal impact on a street driven car. You car will run warmer, but not so much as to cause much (if any) problem. If polished stuff flips your cookies, go for it.
#5, I am tired. If you want, we can continue this tomorrow, but I am calling it quits for the evening.
Basic Sponsor
#5, I am tired. If you want, we can continue this tomorrow, but I am calling it quits for the evening.![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
I need to hear this from a engineer.
Good lookin parts Lart,I didnt do that cam end cap sweet touch
![bowdown](https://rennlist.com/forums/graemlins/bowdown.gif)
Joel, they just oxidise over time so need a polish reasonably often. Not difficult but sometimes there's little places that are harder to get into than others. Try a polish called Autosol if it's available in the States.
Yeah, like engine clear coat.
Hmm... what is hotter, the air around the intake manifold, or the engine parts (head) touching the manifold? If I cared about the 0.00001% of performance lost, I'd say polishing is a bad idea. But it does look awful purdy.
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
1) If you want to be truly accurate the two intercooler pipes need to be handled differently – when under boost the turbo to intercooler pipe will have air that is hotter than ambient engine bay temps, the intercooler to throttle pipe should have air that is cooler than ambient engine bay temps (once the engine bay is heat soaked). So if you want to be a true geek one side needs to be insulated and the other needs cooling fins.
2) Combustion does take place in the headers. If you are running a rich mixture – anything past mid 12’s – you will be still burning fuel in the headers.
3) Polished aluminum does require a little maintenance every now and then – just a simple light rub down with a good polishing compound. 5 minutes for the intake and intercooler pipes a couple of times a year is all it takes. Clear coat a polished part? Looks nice for a couple of months and then it will start to yellow and show scratches that you can’t remove. Polished aluminum is the easiest thing to keep looking nice, little scratches can be polished out in seconds – can’t do that with any coatings (paint or powder)
I am OK with just saying that I like them because they are shiny…..because I do like them just because they are shiny!
Thefu
Racers, the real kind, the one's that throw away millions of dollars a year to win large plastic and metal mantle pieces, would do just about anything to gain a 1/4 hp, an extra 10 minutes of expected engine life, etc. Walk around the paddock at any ALMS race the day before the track goes hot and you'll see plenty of polishing, on the paint and wheels. Absolutely nothing in the engine bay gets polished because it ads nothing to the equation performance wise.
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
