Transmission
Transmission
Ok, a while back my car popped out of gear and has trouble going into all gears now, and when you push it, there is a very audible ticking coming from the transmission with the car off. Not quite a popping, but it sounds like gear teeth barely catching on something. Is this the throwout bearing, or did my transmission go kablooey?
That being said, I may end up needing a new transmission. If you have one for sale, (LSD preferably, but a non-LSD will work.) PM me with price and any other info you feel is necessary. I need a transmission in good shape. (no synchros going out or any other problems, and no leaks).
Thanks,
Adam
Edit: Will also consider 968 trannies
Thanks,
Adam
