Is this a bad DV sound?
ok... from reading on here that happens because the DV isn't releasing the boosted air fast enough correct?
If so, I gotta figure out what to check. I was experiencing compressor surge with the stock dv so I replaced it with an aluminum one (ebay comes with several springs). I'm still getting the surge.
No, not yet, just got the thing installed and went for a drive this afternoon and heard the same thing again. I've got a couple hours before work tomorrow, I'll try to take it apart and use a different one.
Did you check all vacuum hoses, including the black hose that adapts the DV into the j-boot? Check the j-boot itself? I could really see the vacuum hose that leads to the DV to causing comp surge if there were a leak. The valve wouldn't fully open.
I dont think thats compressor surge. I doubt you were generating enough pressure in those runs to outflow your DV. It sounds more like the DV value fluttering, issue is to do with the spring rate in the old bosch. Its not really the end of the world. I tried a few different springs on a 50mm tial valve and got rid of most of it, the sequential HKS ones seem to work, some these days are adjustable so you dont need to shim the spring or change it.
When I installed the new DV I didn't see any cracks but I didn't pull the whole jboot off. I had all new vacuum hoses done earlier this year and the car pulls hard. I'm just the only one in the area now with a 951 so I have nothing to compare to.
I can tell you absolute certainty it is compressor surge (actual defined term is axi-symmetric stall). It really doesnt matter how much boost is being made, the surge is caused by rapid changes in air pressure that causes buffeting in the the compressor housing. This is why a bypass (recirculating) valve works. It recirculates the boosted pressure to the inlet side of the compressor to keep the turbine from having a stall condition and causing the surge. if the valve does not actuate quickly enough, you get the surge effect, if it does not flow enough, you get the same effect...what happens is that pressure tries to back flow through the turbine and causes this effect, putting alot of opposing forces on the turbine wheel and shaft...
Compressor surge sounds like a rapid whoosh whoosh whoosh sound... but not all sounds the same. Typically when you hear one that sounds like a turkey gobbling (really high pitched) you need to start looking for compressor wheel damage.. anyway, here's a video (sorry, its the best example I could find) of what the most common sound for compressor surge is... listen all the way to the end, and never mind the chipmunks...
http://www.youtube.com/watch?v=udXdXCv1r2Y
