Coolant Hard Pipe
Coolant Hard Pipe
I just added an AC delete bracket but the hard pipe that is used for cooling doesn't align right. I noticed in some engine pictures that a rubber hose has been used in substitution of the hard pipe.
Does anyone have any info on what has been used?
TIA
TIA
I did as Thom suggested, i shimmed the engine lift ring using a bunch of washers. Not the most elegant solution but it works . That a/c delete bracket should have no effect on the routing of that coolant pipe.
Check out my pics on my post "finally finished cleaning the engine bay"
Jason
Jason
