DIY Delrin
We mill out parts for custom radar detector installs at work, and one of the local crew here mills the stuff up for bushings, etc. it's a very easy material to work with.
Yeah, easy if you've got a mill/lathe. Previous owner of a turbo ford escort I had turned his own delrin bushings for all the suspension. Even with 250#F/200#R springs it had zero body roll and was extremely stiff as the bushings took out any bit of slack. Was a fun car.
I used to make all my own bushings for my crane.... They are all square with threaded holes though.
Its easy stuff to work with. A wood lathe would work just fine.
