k26/6 Discussion
You guys should really be changing the hotside of the turbo, upgrading to a number 8 hotside is a way more effective than going from a 2.5" exhaust to 3".
As a matter of fact, I'd even consider a 3" exhaust a total waste of time if you have a stock k26/6 and you've already removed the cat and have a free flow muffler.
A. Buy a stainless steel full 3" exhaust for $1200 to reduce preturbo back pressure
or
B. Buy a k26/8 for around $350 to reduce preturbo back pressure a lot
In my experience, going to a number 8 hotside increases exhaust noise by 15-20db ( with an aftermarket catless exhaust ).
Im not saying a 3" exhaust wont increase power, but in my opinion, after removing the cat and changing the muffler, the next real restriction in the exhaust is that number 6 turbine housing.
But let's say you weren't an asthma-causing cat deleter and ran a cat. Then how about a 3" exhaust with a new cat and muffler with the k26/6?
not this again
Yes the 26/6 can create 15psi map at 6500 on the 2.5 engines
If you aren't seeing this then either your wastegate needs attention, your exhaust after the turbo, or your software, or your controller settings
I have data logs to prove this, they are on rennlist somewhere
I was using a stock high mileage wastegate, shimmed with 2 Lindsey shims
2.75" downpipe
Stock, de-catted mid section
Autothority Stage 2
Stock Cycling Valve
2.75" downpipe
Autothority Stage 2
Stock Cycling Valve
Professional Hoon
not this again
2.75" downpipe
Autothority Stage 2
Stock Cycling Valve
2.75" downpipe
Autothority Stage 2
Stock Cycling Valve
not this again
2.75" downpipe
Autothority Stage 2
Stock Cycling Valve
2.75" downpipe
Autothority Stage 2
Stock Cycling Valve
I had a tial 38mm wastegate, MBC and a catless straight through 2.5" exhaust and I could never hold a steady 15 psi to redline with my k26/6. Immediately changing to a K27/8 turbo with no other exhaust/wastegate mods allowed me to hold a STEADY 16psi from 3k to redline.
I, along with many others, have had to set their MBC with a k26/6 to 18-19 psi if 15psi was desired at redline...which actually safely gives a serious midrange kick and reduces some backpressure after 6k rpm.
and make sure you check out his Camaro while there.. it is a BEAST!
Can you port the stock K26/6 turbo? I know that was a cheap easy upgrade for Talon's and eclipse's back in the day. It wasn't a huge increase, but every little bit helps?
I have heard this argument since 2003. I don't remember every seeing anyone (including John Porssccchhh951, who made 300whp on a 26/6) that could hold 15 psi to redline. I could be wrong, but again I don't remember reading it. I certainly can't, I am at 13 or so psi at redline with a shimmed waste gate, full exhuast and all new vacume lines.
