Look at the spring that helps the door "close" you want to "loosen" that spring but it will not add more fuel, it will just make the door open a lil sooner.... if you wanted to try and "adjust" the fueling you can do it at the DME, I think its like a 3 or 4MM Allen wrench and turn it 1 click "clockwise" should be 5% more fuel over the entire powerband....
If I am mistaken, someone will correct me Im sure of it.....
Good luck..
Went to my mechanic instead. It was the best thing I could do.
1. Change my spark plugs... all tips where white. Car was running to lean
2. Added 3% more fuel at the dme
3. Did a test a yes (f**k), I've blown a gasket with that Lindsey Racing Boost Enhancer, I had to much boost.
What a day. What a day. Now I need to check my things if I do this year or wait next spring.
