Clutch master Hose
Clutch master Hose
Hey how hard is it to change the clutch master hose that goes to the slave cylinder. I replaced the Master and the slave already but I'm dripping from the hose....figures just when I'm getting it ready for sale.
Easy peasy. It unbolts right at the firewall at the back of the engine, it's really pretty convenient compared to other setups I've seen. Hardest part, as always, is bleeding the air out of the line after you replace it. Should take you an hour from walking out to the garage to cracking open a beer.
Good luck .. I think its about 35 bucks for that hose from Sunset ... ( that hose can get pretty toasted being so close to the exhaust ..
Good luck
Regards
Ed
Huh, mine didn't have a clamp (granted the line also wasn't original, looked like a hydraulic shop special with braided lines), guess I'll be adding that to the list of "small parts the PO neglected to leave on the car and I now have to order."
Here is a picture of the clamp above and if you look you and see a stud sticking out just below it ... I assume that is supposed to hold another clamp ( this one for the wires to the starter ... Does anyone know the size that cable clamp is supposed to be ? i.e. Norma 23 ..?
Thanks in advance
Regards
Ed
