Jackstands.....a question
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
The frame rail will ‘squish’ if you use a small contact area. Typically they get squashed when jacking not from being supported afterwards. If you make up a small square of good plywood (at least ½”, ¾” is better) that is 6” x 6” to spread the load you will not have a problem.
If you use a floor jack then jack it up by the correct point midway down the rocker panel.
Harbor freight has some 12 ton jack stands that give you quite a bit of working room.
Torsen tube….now that’s a cool mod!
Defending the Border
Rest In Peace
Rest In Peace
Do you mean the black bit that sticks out about 4 inches?
Anything up front scares me, stability is a bit narrow for my likes. I have new 968 castors so those have become my jack stand points, used very carefully.
I still keep the floor jack under the mid-sill lift point.
