86 951 for sale
86 951 for sale
I decided I'm selling my 951. The car pulls hard and shifts good.
The good----------------------
Rebuilt ported head by chris white
ARP head studs
MLS gasket
Tial 38 with adapters
SFR downpipe
SFR testpipe
Turbonetics 62-1 10cm
86lb injectors
Aluminum radiator
Aftermarket fan
A/C delete bracket
Lindsey shift lever
VDO boost gauge under radio
Manual boost controller
Vac manifold
Solid trans mount
30mm swaybar with delrin
Pagid pads with new rotors
Toyo T1R 245-45-16 with 20k if that
Intercooler pipes for godzilla bov
Oil catch can
Aluminum balance pulleys
Powdercoated crank pulleys
New hoses
6 puck copper clutch
kep pressure plate
New clutch bearings and hardware
Manual steering rack not currently installed
Interior is from a 40k car
The interior insulation and sound deadening pads were all removed and the carpet put back.
Sunroof bolted shut
Replacement door comes with car
Receipts for most of the parts
The bad----------------------------
dented drivers door (have replacement)
dented drivers fender
broken odometer
needs axles
Must be picked up in NJ
$3500 firm
ARP head studs
MLS gasket
SFR downpipe
SFR testpipe
86lb injectors
Aluminum radiator
Aftermarket fan
A/C delete bracket
Lindsey shift lever
Vac manifold
Solid trans mount
Oil catch can
New hoses
kep pressure plate
Sunroof bolted shut
broken odometer
needs axles
$3500 firm
The block off plate is only there because the screw holes were cracked off the climate control and i got sick of looking at it hanging. There's no a/c and I dont drive it much in the winter so it didnt bother me not having the controls there. The odometer reads 150k but the car probably has about 5k more than that because the odometer recently stopped. History? That i know of the car was in a front end collision damaging the front left corner, the fender was banged out but could use a new one or some filler. I bought a replacement headlight bracket online and its slightly bent where the cover wont fit without rubbing, i never bothered to go through the hassle of sending it back and locating another one. I bought it with a not so great body and when it got hit i gave up and now i want something different.
bump, still available for 3500 or trade for a fox body mustang, 70s-80s chevy or dodge fullsize 4x4 pickup, smallblock chevy s10, or anything else interesting you can run by me.
