Vacuum issue? 86 951...
Lifetime Member
Lifetime Member
No love on the 924/944/968 board. Figured here would be better...
After acceleration or revving the engine, then releasing the throttle, the rpms drop and the engine quits.
So what's the first, second, and third things to look for?
Small Business Partner
First, make sure your idle speed is adjusted properly.
Idle Speed Adjustment
TPS second. Make sure the idle circuit is working properly.
TPS testing
Third, boost/vacuum leaks. Make a tester:
Intake leak tester
TPS testing
Intake leak tester
