Few new things to install
UPS dropped these off today, I ordered a smaller windshild resiviour so I would have more room to help w/ cooling to brakes or oil. Not to mention, I really did not want to have to refit the original one, was kind of a pain to remove. Ha, can actually see through to pavement as it is about half the size.
Also, I won't install the rear seat delete, until i have the rollbar installed. Then I will use some of the extra carpet I have to match the car. I also have some vynal dye to color match my interior from the gray. I was supprised how much room was in there.
Steve
Steve
And I thought CurtP did the rear seat delete himself. That is a nice piece! Dont suppose you could share wt. out and wt. in and your source? +1 on the reservoir change, with 'RainX', its just wasted space.
Not sure what wt. out and in means. If weight, it is not very heavy maybe 30lbs.
I need to call the shipper as it was damaged in shipping. One of the doors does not close correctly and the decking is broken in a few areas.
![grr](https://rennlist.com/forums/graemlins/cussing.gif)
Edit: looked over it a bit, with some fiberglass,brackets and some screws, should be able to get it right, I think.
But it should be nice when done.
Steve
