How to remove tach needle??
Steve
Location: Hawkinsville / Perry, Georgia, RETIRED USAF GO BLUE
1 Post
Hi DrZ1, Take a look at the link below for the LED up grade and repair of the dash lights.
For the needle removal: Put a sliver of white tape where the needle now rests. I used narrow long nose pilers wrapped in tape to hold the needle pin in place and a fork to lift the needle straight up and off the pin.
https://rennlist.com/forums/944-turb...e-writeup.html
Cheers,
Larry
Cheers,
Larry
*Edit: I do recall in the instructions that it said if you want to have this particular kit to be able to dim, you need to install a potentiometer in the circuit. When I tried using the stock dimmer wheel, it kinda works, but doesn't really dim the gauges very much, but I never bothered installing a pot since I got a blue LED kit to look at anyway.
