Power mods for a basically stock car.
Old 09-15-2010, 07:19 PM
racerxrick
racerxrick's Avatar
I've seen 18psi and it DOES NOT drop at redline! The car goes like stink.
I do have a quality wastegate..
Old 09-15-2010, 07:42 PM
onspeed
onspeed's Avatar
And you're using a k26/6? I thought the reason Porsche switched to k26/8 in the S and 89's was because the k26/6 couldn't hold boost?
Old 09-15-2010, 07:53 PM
racerxrick
racerxrick's Avatar
my friend did the mods when he owned it. When he bought the car it came with a pile of maintenance receipts. As far as we know it's the stock turbo. I was going to do a MAF conversion when I first bought the car. After driving it and reading up I'm not sure that I would benefit from that conversion due to the stock turbo.
I drove the car before and after the mods...in fact I was the first to drive it after the mods! I've had a number of drag cars and quick street/strip cars and my buddy wanted to see what i thought. DAMN is what i thought and now i own it!
From what I've read and from your post (from my limited experience!) it sound like exhaust should help you a bunch!
I can't remember which wastegate he swapped (was one of the last mods) but I know he went with a nice billet one and said that it held and controlled the boost much better.
NOTE: I don't make a ton of boost down low..but third gear on it holds rock steady when the car is under load.
Old 09-15-2010, 10:46 PM
Black51
Black51's Avatar
^^^ I've got a similar setup so I'll chime in on that. My car hits 17 psi in 4th/5th gear pulls up to ~5400rpm on the original k26/6. I'm positive it's a 26/6. So ya, the k26/6's will hit over 16 psi. I think the reason why Porsche ever so diligently switched to the 26/8 was because if you look at a dyno chart comparing the 2, the 26/6 drops off like a cliff because it can't HOLD the boost as long as the 26/8. So it won't hold the torque and thus won't let HP climb much more. That's exactly what happens with my car past 5400rpm; time to shift up or she runs outta *****.
By the way, I'm running a LR DP wastegate, not currently running a MAF.
Old 09-16-2010, 01:09 AM
minho78
minho78's Avatar
Russel Berry makes a nice chipboard. I was running APE setup and was running very lean in my case. I bought Russel's Multiboard and it's running very close to target eventhough it's a APE maf. My AFR attached (Manny Fernandes/Blue).
Old 09-16-2010, 10:27 AM
toddk911
Drive-by provocation guy
toddk911's Avatar
Hmm, I was always under the impression that the stock k26/6 couldn't do anymore than like 16psi. That's the general power range i want to be in though.
Also, anyone have any experience with Russell Berry's Multi-Board DME chip? Same guy that sells the 951MAX chips if I'm not mistaken. All I'm looking for, in terms of chips, is something that has a better a/f line than the APE, which is said to run really lean in the higher RPMs. It's a street driven car, so I don't need, nor want to pay, for 100% efficiency. If his stuff will be 90% as good (which is probably still 100% better then these old APE tunes) then that's fine.
Yes, I have. Obvioulsy there are other products and some that are top notch, but for me like you mention the 90% factor, it is not worth the great deal of extra funds for that 5-10%. Just my opinion. lol
Old 09-16-2010, 10:49 AM
slap929
slap929's Avatar
minho78, what all has been done to your car?
Old 09-16-2010, 10:53 AM
minho78
minho78's Avatar
Not much. APE MAF, Russel Berry chipboard, 3" catbypass.
Old 09-16-2010, 11:00 AM
Darwantae951
Darwantae951's Avatar
Then your turbo is not stock. The #6 hotside can't hold stock boost pressure (~11psi) to redline, let alone 18. I never saw boost bleed off with my old #8 at 15psi, but I never pushed it higher.
Old 09-16-2010, 11:15 AM
slap929
slap929's Avatar
Modded, when is your project car going to be done? Need to post pics or better yet video of it.
Old 09-16-2010, 11:46 AM
Darwantae951
Engine is about ready to go in, I have a thread if you search under me. And there will be video once it's broken in and dynoed.
Old 09-16-2010, 02:07 PM
Euro951
Euro951's Avatar
My car with a fresh engine rebuild and a stock K26-6 can hold 11/12lbs of boost to redline easily with a Tial.
Old 09-16-2010, 03:30 PM
Darwantae951
I personally have never seen one hold till redline. Even with dualport wastegates. Lots claim it can, and lots say no. Video it and I'll change my mind.
Old 09-16-2010, 05:41 PM
slap929
slap929's Avatar
Numbers just seem lower than I expected.
Old 09-16-2010, 05:44 PM
TurboTommy
TurboTommy's Avatar
It might be possible that with certain wastegates the stock turbo can hold more than 12 psi boost to redline.
But, the bottom line is that the stock compressor can only flow for a little over 300 crank hp (maybe even less if the ambient pressure it sees is less than ideal). So, it doesn't matter how much boost you're seeing at redline, that's all the power you're gonna get.
I know a lot of guys get real horny when they see their high boost reading at redline, but chances are their making very little more actual power than the guy witnessing the boost bleed-off thing. That high boost reading looks good on the boost gauge but it's all turned into heat and crazy back pressure.
The orginal poster said he'd like between 300 and 350 rwhp; so you have to upgrade the turbo.
Quick Reply: Power mods for a basically stock car.
