10% off all Ishihara-Johnson Crank Scrapers & Windage Trays
Former Vendor
Last month, we added Ishihara-Johnson's products to our lineup. As an introductory offer, we're offering 10% off all of crank scrapers for the 924 & 944 series from now through the end of September.
Single Scrapers
$72 (normally $80)
Single steel scraper for Porsche 944, 951, 968 2.5L / 2.7L (both 78.9mm stroke as used in 944 variants); 3.0L (88mm stroke -- as used in 968, stroked version of scraper)
$180 (normally $200)
Teflon® stock and knife-edged version, including the rear screening found on the windage tray setups (see below).
Teflon scraper for 924S/944/951/968
Full Windage Trays & Scrapers
$324 (normally $360)
Full windage setup with steel scraper.
$414 (normally $460)
Full windage setup with Teflon® scraper.
Windage tray for 924S/944/951/968
To Order
2.5L / 2.7L / 3.0L variants: http://garage.ideola.com/prod-944-p001.html
2.0L (924 / 931) variants: http://garage.ideola.com/prod-2LEngineMods.html#IJCS
NOTE: when ordering the full windage setup for the 2.5L/2.7L/3.0L series, you MUST indicate which style of oil pan your car has, as there are a couple of variations that impact the specific design of the windage tray.
Each scraper is custom fabricated by I-J, so please allow 3 weeks minimum for order fulfillment. Please PM or email (dan DOT beckett AT ideola DOT com) if you have any questions.
Single Scrapers
$72 (normally $80)
To Order
