Air bag delete
Disconnect the airbags at the wheel and dash. Then unplug the airbag controller. Take the plug on the car side of the harness and use a wire to jumper pins 3 and 4. That will allow the fuel pump to run. Then secure the wire in the plug, and the plug under the dash. No airbags and no warning.
Be sure to wait about 30 min after disconnecting the battery for the capacitor in the airbag controller to dissipate. Don't want them going boom in your face.
More or less the same information as above, but here is the link to the procedure I used. http://www.944s2.com/how-to/how-to.htm
If you are REALLY motivated, you can do it like this: http://forums.pelicanparts.com/porsc...hlight=airbags
Cheers, Keith
Cheers, Keith
