Anti-lock light??
Anti-lock light??
Hey,
I have a 89' 951 and my anti-lock light comes on every now and again? It goes off most time. Has any one had a similar issue and what could be the grimlin??
Thanks for your help!!!
Mike
Mike
Had the same issue, would come on after a few minutes of driving
and stay on. Wouldn't happen all the time. Replaced the relay in
the main fuse box and the problem never returned.
I had to replace the cables that go from the body connectors to the wheel sensor connectors. The light would go on whenever I hit a bump at just the right speed. Since they were all deteriorated, I just replaced them all and they were not cheap! No more abs light.
As these systems get old, you could be getting the light for any number of reasons. Try cleaning all of the connectors first and make sure everything is tight and secured. The little cable holders and connector housings are still available and not too expensive, but will probably break when you start taking them apart.
