951 2.5L Top Speed Records?
#61
Small Business Partner
I can believe wheelspin is more of a problem on a bike - lowered, rider tucked way down, all the weight on the front wheel... I just don't see it as much of a problem for a car (assuming the car isn't "lifting").
The 997 didn't launch that hard, in fact they bogged it a little bit.
The 951 has a pretty good CD, and quite a bit less weight then a 997. I simply don't see 1000+ hp being necessary.
#62
Location: Encinitas, ca PCA National DE instructor PCA San Diego chief driving instructor
Less weight isn't much of and advantage in such an event, indeed some competitors add weight to improve traction. It's all about power vs drag.
#64
Formula One Spin Doctor
A 997 has much better rear wheel traction due to the engine being in the back (wrong) end of the car. A high powered 951 will launch poorly in comparison, remember it's a one mile drag race.
To go fast in a 951 you're going to have to make all your speed at "the big end" of the track. Maybe 1700hp won't be required to go 200, perhaps it will only take 1200 or so.
Until one of us tries it, we'll never know.
The thing I DO know is that the few cars that knock on 250 mph are making 1400~2000 hp in aerodynamically slippery bodies (Gallardos and GT's)
The Gallardos were making 1400 whp ...
![cherrsagai](https://rennlist.com/forums/graemlins/drink.gif)
Single plug 3.2 911 narrow body , no mods to the body , has more drag than a 951 ..
http://www.youtube.com/watch?v=Y5ebk...ayer_embedded#!
#65
Not sure I'd like to be going 200mph in one of ours cars unless there was some significant attention to downforce....which is going to sap top speed. Seeing that RX7 do it's impression of Mark Webber doesn't inspire me a whole lot.
http://www.youtube.com/watch?v=UPGMtLaRXEw
#66
So, I'll trust my common sense before I believe that data logging equipment implying wheel spin.
Also, this is in effect an acceleration test (not really a top speed run).
Whenever you're trying to accelerate something in a relatively short amount of time and space, weight is an issue, and not of lesser significance as claimed.
#67
Do you crash every time you experience 15% tire slippage? Do you ever compete on race tracks, and if so, do you do it without any sliding/corner exit tire spin up?
I can't believe you guys insisting "this is the way it is" when you have no experience in this type of event.
Remember, I compete at the Texas Mile on a bike (where all the weight of the vehicle is on the rear tire)..... we still get slippage.
Watch some vids of car runs there, see if you think they are getting wheel spin.
hint: they get a lot, some guy in a Gallardo kept spinning out at approx 100 mph last time.
#68
Freedom Enthusiast
#70
I for one am not saying that wheel spin doesn't exsist, and it happens all the time when force overcomes available traction; like you said, slipping in a corner or accelerative force.
But, generally a corrective action will take place; like backing off for the corner with less steering input or velocity, or in the case of straightline acceleration, backing off on the throttle (and you're Texas Mile run is done).
You're implying with this statement:
that the driver just keeps his foot into it to cross the mile marker at high speed, despite the wheel spin, without negative consequences, and it shows up on your data logging equipment.
#71
There is a difference between flagrant wheel spin (over 100% slip) and 15% slip.
http://f1elites.com/4d/?p=54 goes over it...
Without some percentage of slip, you are creating 0 grip.
#72
We can't feel the wheel spin in the upper gears, it's not the "burning rubber" type of spin, (to us ridersit felt like the clutch was slipping.....barely) but the logging -which reads rear wheel speed after the clutch- doesn't lie.
The wheel speed logging and the rpm logging match, so it's not the clutch.
The logging showed 207 mph wheel speed at the point that the lights said we were going 176 mph. The lights don't lie either.
#73
Wow, that's a huge amount of wheelspin at super high speeds. I had no idea this occurred.
So is this just because the rear or whole car is lifting at speed, or is it the resistance of air being overpowered by hp? So pushing against something with resistance, but the power is stronger.
#74
Monkeys Removed by Request
1700whp is really hard to swallow... Especially when these guys did it with with ~800whp:
vividracing 997tt
vividracing 997tt
People who have never been to the mile or don't have much experience with really high hp stuff going fast always seem to believe its just soo easy. It takes big big power to run at the mile fast, no 951 is going to hit 200mph. It's just not going to happen with this platform. I do believe a 951 could possibly hit 175-185mph but, it would take a herculean effort and a ****load of money. I highly doubt anyone here has even made the power reliably it would take to do 185mph in the standing mile in a 951.
I have seen many 600-700-800hp cars looking for their 200mph shirt come up short.
#75
Why was your car experiencing so much wheel spin (i really doubt that ) and you do know quite a few cars have broken 200 with less than 800 whp ......
The Gallardos were making 1400 whp ...![cherrsagai](https://rennlist.com/forums/graemlins/drink.gif)
