Mobil-1 Oil
Mobil-1 Oil
For those using Mobil-1, I was wondering if your having problems obtaining certain weights. In the suburban Philly area, it is tough to fine 15-50 even in Qrts and the 5 Qrt bulk is not packaged that way any longer. I was wondering where your getting your oil?
Not that many people use M1 I guess?
Not that many people use M1... or they don't have instant messaging service for new posts...
The only M1 oil sold in the U.S. that I would use is 0W-40, a Euro formulation. Most M1 U.S. oils have relatively low HTHS and don't meet Euro car requirements.
Supposedly they've 're-increased' the levels of ZDDP in one/some of their products. They have received a lot of bad press for lowering these levels over the years and not telling anyone. This leads to an increase in wear and less protection. The other thing to look for is the amount of detergents in the oil. Apparently if you're wed to the Mobil brand one of their motorcycle oils is a better choice.
I run Lucas in the boat and I'll use it in the 944. If you want to use an off the shelf oil you can get a additive with the zinc in it. http://www.lucasoil.com/products/dis...how&headTitle= - Engine Break-In Oil Additive - TB Zinc Plus
i contacted mobil 1 and they suggest ow-40 as the best choice unless your climate exceeds 100 degrees for 5 or more days in a row
i couldnt find ow-40 in NY so i went with VR1 and have been happy so far
Mike
Mike
Lol about their advice. If it exceeds temps for 5 days in a row or more. haha. What, are you meant to put your car in a time machine and go back those 5 days once it's exceeded this mystical 5 day limit for their 0w/40. What a joke.
Be aware that a company like Mobil couldn't give two hoots about some old 4 cylinder front engined Porsches.
0W/40 is too light in general terms.
I'm not a M1 fan but the M1 0W-40 Euro formula is a good oil approved by most Euro car makers and suitable for most applications. The recommendation of not using it for sustained 100 F temps is very conservative and maybe even poor info. as this oil is run in 100 F temps by millions of Euro cars daily with no issues.
http://www.ideas4ag-ed.com/uploads/3..._viscosity.pdf
Thanks for the tips but there has been quantifiable evidence from real mechanics who work on flat tappet engines to show that low visc (sometimes synthetic) oils increase wear and don't offer enough protection. Especially for track oriented vehicles.
Here you go:
http://www.landsharkoz.com/tech/bb/bbipr.htm
http://tiny.cc/zt5f9
Here you go:
I won't use a synthetic/M1 in a 944 anymore. Our engines were designed around the Dino oils of the day, not synthetics. Sooner or later always had leaks with M1 and question other wear problems experienced. Don't care what they say. I stick with Dino only and happy with Valvoline.
