Idle cannot be adjusted with idle screw...
I recently changed my TPS and I have the venturi delete, but my idle could always be adjusted with my idle screw. After warming up I notice it idling at 800-900 and I usually keep it at 1,100, so I loosened the idle screw a little and no change in rpms, I blew into it and it was tight with no air leaks, why can't I adjust it?
1,100 is way too high.
![nono](https://rennlist.com/forums/graemlins/nono.gif)
you have to connect two ports on the diagnostic port to take out the IAS, then your screw will work properly and it will Retain your set idle. Short B and C ports, start the car, set your idle, turn the car off, remove the shorted wire, should be good to go - provided your hardstop and TPS are set right.
