Header Panel Ideas
Rocket Scientist
I would think twice before installing any duct in the header panel. The best airflow for your intercooler is how the factory has it setup with the correct factory ducting. A vent behind the intercooler in the hood near the hood latch would help you, but a vented header panel, in my opinion, will do more harm than good.
I've been told by club racers that a vented 951 nose panel gives them second(s) on a track, given no other mods.
Can someone else chime in here and confirm if there is any validity in this statement? I don't think the racers and guys with built 3 liter 951's run vented nose panels purely for aesthetics...
Derek's statement is absolutley correct. You need venting to pull air out, not to shove unfocussed air in. Unless you intend to create a custom duct that will seal against the IC, you are hurting performance, not helping. The IC will not do it's job as designed without proper ducting. Do a search here. It's been thoroughly discussed.
My search yielded this thread: https://rennlist.com/forums/944-turb...vent-test.html
The test's confirmed that the 931 header panel lowered intake temperatures at cruising speeds by ~2 degrees.
I agree that saying it's worth seconds off a lap is an outlandish statement, but would you disagree that a 951 at high speeds with a vented header panel would make slightly more power due to a denser (cooler) intake charge?? That increase in power should theoretically produce a (slightly) faster lap time, given ideal conditions for testing.
Also found :https://rennlist.com/forums/944-turb...-benefits.html
Which Ehall contributed to. It seems that however slight the intake temperature difference may be, the general consensus is that it's not worth the effort given that it takes consistently high speeds (ie hard tracking) to notice the slight benefits.
It had nothing to do with the effect upon the IC, which is more important.
Back on topic,
Adam, lots of good stuff in this thread; https://rennlist.com/forums/944-turb...se-panels.html
on my old 86, I had one that I got from Daniel951. It was exactly like his. As I said, it looked nifty. You should look at what he did and copy him. It was a super piece. It fit beautifully, as it should have, being a stock machined piece.
A vented nose panel by itself will just push air forwards quite possibly. Well to rephrase, you will create a high pressure stall zone. However doing it on a road car won't make much difference either way. If it was a great idea Porsche would have done it on the 951. Having said that, if you have some sort of exit vents in the hood, that could possibly make a difference. Unless you've a spare wind tunnel this is all just bench racing really.
I had a vented nose panel with no hood venting and didn't perceive any change nor see any temp difference....but I liked the look. I now have it sort of blocked off behind the venting and ducted towards the radiator. My temps don't climb above the first line even on the track. I think hood venting is helping too. Emphasis on 'think'.
