Venturi before turbo?
Professional Hoon
intake mods: AFM Link map sensor...
would it make some sort of difference if i did put this there?
just something ive been thinking of for a while.
![](http://i107.photobucket.com/albums/m311/tha-wog-boii/IMAG0047.jpg)
Engine bay, you can see how the turbo intake is set up.
![](http://i107.photobucket.com/albums/m311/tha-wog-boii/IMAG0022.jpg)
if will only make any difference un noticeable either way if there is a big step in there now .. wich there probably isn't..
a better way to spend the after noon is a MAF trap or divider thats you put the inlet pipe through to stop to seperate the engine my heat from the air filter .. give me your email adress and I'l post you the drawing i got on here ...
