no fuel at 15 psi
Small Business Partner
If the 924 is the "S" version, then yes they will work. If it is the regular 924 (with the audi engine) then the leads will not work.
Professional Hoon
dammit it's the 1980 924 2L, no car untill tuesday.
cheers for your help so far Rogue,
if this dosnt fix my problem il be here for with more questions
- Paulyy
- Paulyy
Professional Hoon
so i put new NGK spark plugs in my car and TopGun MAX300 ignition wires, it drove good, i did get 15 psi with a richer mixture but didn't get a good chance to go WOT much because in AUS its been raining and damp for the past week or so
Professional Hoon
i went WOT in 3rd gear all the way untill around 6k it drove better but i felt small jolts like is gets petrol then not enough then it has more then not enough? whats going on here or this might be the LINK afm unit? since the enrichment is per every 500 rpm?
Even though the adjustment on the Link is every 500rpm, any rpm value in-between is interpolated from the adjacent cells. So it is not an issue with the Link not provide the proper signal between cells.
You said it was better with the change of plugs and wires, have you checked your cap and rotor lately?
Professional Hoon
last time we looked at it well me dad did, he said it was alright back in march when the headgasket went.
what would i look for on the cap and rotor?
Burnt/eroded rotor or contacts.
That changing your plugs and wires made it run better, makes me think ignition related. However, I also suggest checking your fuel system as well - I know you have the AFM-Link setup, do you have a WBO2 and knock counter? Else, how are you tuning?
Professional Hoon
what's a knock counter?
il check the cap in the morning when theres light.
the way i tune, your going to think im stupid though... NBO2 but i aim for the 1 or 2nd green light on the gauge, im looking at WBO2 sensors just looking for the right one, the car is pretty much tuned by the PO (OZ951) im just touching it up now since after the head gasket blew and an intake gasket was gone also.
Well, the head gasket blowing should be a sign that the tuning wasn't spot-on...
WBO2 are quite cheap now - I highly suggest picking one up.
The knock counter is quite cheap and easy to install, check out this thread:
Knock counter thread
-Rogue
-Rogue
Professional Hoon
i cannot say the head gasket blew on the tuning, when i removed it, it looked like the original one from 120,000 miles ago. when Wayne had the car he noted the headgasket had an oil leak but wasnt sure so he left it. i might go WBO2 shopping tomorrow, il take a look at the thread and il post back here.
innovate seem pretty good but tech edge are in sydney so you would have it sooner
http://wbo2.com/3a1/default.htm
http://wbo2.com/2j/default.htm
and if you want something to make you crash because it looks so cool your plying with it
these gtech expandable guuges have an WB02 controller and do 0-100 1/4 mile later g's braking etc
http://www.gtechpro.com/egs.html
