2" J-Boot
Basic Sponsor
We are in production on our Silicone J-Boots for 2" inlet turbo's (K-26's). We have the
3" now (TO4E's), and have an adapter to make that work on a 2-3/4" (K27's/TO4B's). End of July release in red, blue and black.
![](http://www.lindseyracing.com/pics/2inchJBoot.jpg)
All the AOS hoses at the tank and up front (both versions and custom versions to eliminate metal tube), Cycling Valve, Fuel Vapor Vent, Banjo Bolt to Hard Pipe... are all currently in production as well. We will have every hose on the engine in silicone soon in all colors.
We are entertaining different colors. It was one thing to buy yellow plug wires when you couldn't get any other hoses in yellow, but now we may offer yellow because we can offer every hose under the hood. Silver or Grey/Charcoal is also under consideration. Ideas there?
Mike or Dave Lindsey
U.S. 1-877-943-3565
Other 1-405-947-0137
U.S. 1-877-943-3565
Blue is good for me. I also have a quesion for you. I am in the process of replacing my blown motor (race car/avatar) and want recomendations on "while your in there" parts. The only thing currently on the list is a 3 piece cross over.
Basic Sponsor
Give us a call, and we can discuss the options.
Basic Sponsor
"IF" you are needing to buy a new J-Boot at some point, as many people do as the factory one crumbles at the turbo, you now have an option. This should take the heat better then the Rubber part (OEM). If you like the smooth look, you can have a black smooth one. If you like red or blue, you can have that also. We are going to be supplying the stubby 90 hose from the BOV to the hard pipe with them as a team in color as well.
