It's official, the car is cursed.
#62
Pretty much it is a K26. Markings on it are K26-7200...
Read the Clarks Garage DIY, it's something I can do, but doubt I'll have enough time strung together to knock it out quickly. I may punt on this one just so I can have the turbo off the car and getting rebuilt asap.
#63
#67
Doc you have to look at the bright side, you have a healthy engine. All you have to do now is to get that turbo rebuilt and then enjoy the car again. I think I have the same issue as you with my K26/6. So I think is time to throw the 27/6 that I have laying arround in there. Keep us posted.
Manny
Manny
#68
Oh, I'm very happy that there are no motor issues. That would've spelled the end of the season for me and me yanking the motor in favor of an LS1.
Just have to take this turbo off and get it rebuilt, then back on the car..
#71
#72
Get a new bung for the wideband sensor downstream of the turbo as well. Wideband sensors dont do well with the heat AND pressure that are pre turbo. Their sensing cells are more complex and delicate than narrowbands, which is why they cant go pre turbo.
And the sensor must be angled upwards towards the roof of the car by at least 10 degrees from horizontal, basically the end with the wires must be higher than the end in the exhaust. It CANT be perfectly horizontal, or wires end lower than the sensing end. This prevents fluid from collecting and ruining the sensor.
#73
Yep, might as well check for the restrictor and install it and see what happens. Worst case need to send the turbo off for a rebuild anyways.
I can get to the oil feed line by removing the intake mani, but don't need to remove the turbo itself?
#74
Beware theres an oring under there on the turbo, and youll need two 12mm crush washers at the banjo bolt on the balance shaft housing.
