Is it just me? Or is this venturi delete diagram from Lindsey incorrect?
Is it just me, or is this diagram from Lindsey incorrect?
This diagram shows the vacuum line furthest to the left on the cycling valve routing to the banjo. I am keeping the 3 welded metal tubes under the intake and it appears that using this metal piece the CENTER vacuum line from the cycling valve will go to the banjo and my furthest left vacuum line from the cycling valve will route to the j-boot. This appears to be the opposite of what the Lindsey diagram shows.
In other words, utilizing the welded metal tubes, the 2 lowest GREEN lines (NOT going to the wg) on the above diagram seem to be reversed.
Am I wrong? Or just too tired to figure this out?
