Early engine harness red connector to late flat black one
Anyone have a schematic handy for going from the red square in the car 4 pin connector to the late engine harness black flat 8 pin but 6 wire connector? I think the late one is larger because it carries the signal wire for the low oil level sender?
Josh - do you have the service manuals? When I replaced the main harness in the '87, I used one from an '86 and made my own adapter. I will be tearing out my dash soon and I can get you the pinouts, but it may be a while. I just looked at the two schematics and figured out the pinout.
And yes, they changed the connector because they added the low level sender.
