Clutch slipping at high speed/load
![soapbox](https://rennlist.com/forums/graemlins/soapbox.gif)
Well, passing 130mph the other day in 4th gear I noticed a clutch/brake smell and that the rpms seemed to be climbing faster than the speed. Sounds like my clutch is slipping, eh?
How many miles have you guys gotten on a clutch? I am around 50K miles, 15K of which at 17-18psi and the rest at 15 psi and I drive the car pretty hard (without abusing it)
Is there anything terribly wrong with just replacing the clutch disk (i.e. reusing the pressure plate) ? Is it worth getting something beyond the Sachs disk?
Drive-by provocation guy
when I had mine done after years of hard driving and 15-18psi, all that was changed of major parts was TO bearing and disk; which I went with the Cup disk.
The Cup disk with 18-20 psi and about 330-350whp has not slipped at all.
Doesn't seem worth it not to also change the pp, throw out bearing, guide tube, pilot bearing, etc. You can generally get the flywheel turned for cheap--I'd at least do that personally. You can check the rms at the same time.
Small Business Partner
If your in there, I would definitely look at a better clutch disk - especially if you plan on re-using the PP. The southbend feramic sounds like a good option, IMO.
If you got 50k slip-free miles out of a stock clutch, I'd be inclined to stay stock and just switch to a cup disk.
