Gauging interest in some Vitesse products and 27/6 turbo
I am consolidating my two 944's into one, so I will be listing as they come avaiable.
I have a Vitesse piggyback that is about a year old. I can sell with or without the entire 944 harness of an 86 turbo, so a 24 pin setup. I can take pictures later, but it would save alot of soldering and tracing the wires to install.
I also have a boost solenoid that will work w/ the PB, but it can only be supported though Vitesse if you have the MAF. It is also wired into the harness.
Also in the harness is a WB display and Innovate LC-1 which is availale in the package as well.
I have an AFM chip that is setup for a 27/6 but I would assume being a piggyback, it could be adapted for any turbo. Also the chip can be used for BOTH stock and 55lb inj, the FQS just needs to be changed to select which one. I will sell the DME with the setup, if needed.
((John if any of my information is inccorrect, please chime in))
Also I have a 27/6 quick spool turbo by Evergreen turbo, that I can sell with or without this setup. I will have it off and available in 2-3 weeks.
If I have all or most componets sold I will seperate the package. I am not sure on pricing as I am not sure how the package will be divided up.
Please PM w/ your interest, I will keep in order and arrange the pricing as well as working on some photos.
thanks
Steve
thanks
Steve
Forgot some pictures.
I can take more when I have the complete harness off the car. There are some additional wires in the harness, as I had the PB wired with an Innovate LC-1 wideband. I have the wires neatly tucked into a braided sleeve.
Steve
Steve
Steve, It makes sense to keep the turbo, chip, PB and injectors as a single package. This will be the best value for someone looking to upgrade.
Considering the amount of time and care you spent on the wiring, someone should ****** it up in no time.
Good luck with the sale.
This I know,
I think I can sell the Turbo, no problem. The injectors are stock. Which leaves the chipset, that will be hardest to sell by itsself. Although there is alway's Ebay![ooops](https://rennlist.com/forums/graemlins/icon501.gif)
Steve
Steve
