I'm not sure you can get a 110 for the timing belt. Its a 117. Balance shafts need 110. If your supplier doesn't know the difference it'll be obvious when you attempt to install it.
Yeah, it's not going to be difficult to tell the timing belt form the balance shaft belt. I had a hunch it is the 117 tooth belt. Do 16 valve cars use different belts?
