Reference sensors
They are Hall Effect proximity sensors. Very much like ABS wheel speed sensors. They are mounted a set distance from the flywheel. When a flywheel tooth passes by (for the speed sensor) a tiny signal is generated. The DME reads this and calculates engine speed. The reference sensor reads a stud that screws into the flywheel. When this passes by, the DME reads that as TDC.
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
