Remote oil cooler metric fittings - sizes & where to buy ?
Anyone know the sizes of the metric fittings on the hoses going to the factory remote oil cooler (and where to buy them) ?
Also are metric adaptors to standard -AN fittings an option ?
Since I've got a decent sized oil cooler lying around from a previous toy car, and it's fitted with -12AN sized terminals, I though I'd just get a couple of adaptors, some -12AN hose and make my own remote cooler up...
yup... did some more... found this thread eventually !
https://rennlist.com/forums/944-turb...-fittings.html
22MM to -12AN is what you need.
http://www.pegasusautoracing.com/pro...asp?RecID=4213 or from www.batinc.net
I just did this recently. You will need two M26 to 12AN adapters if you are going off the hose ends that attach to the cooler (using the stock lines). BAT - British American Transfer has them. "NOTE" - I had to have the hex nut machined off so the stock metric fitting would seat all the way on to the adapter. Test fit before you install.
FYI - I searched prior to my install and found confusing information on the adapters sizes. Call BAT.
