Does the ISV interfere with vacuum pressure?
I am wondering if this is my problem of bouncing erratic idle and power loss. When the problem occurs, the idle is lower than normal and the bar gauge is above the lowest point, which is not normal(it is usually all the way down when the car runs good)
It seems to pick days that it works and doesn't work.
Does the Idle stabilizer Valve change vacuum pressures at all? It seems like it would. If it does, I believe that is my problem.
thanks
thanks
