Need Left Power Window Motor
Hi,
The driver's side power window finally stopped working on my 951, fortunately on the way back from the airport on a dry, Spring night. The passenger side works just fine. I have confirmed power as far as the window motor connection, so I am pretty sure it is the motor. it also doesn't make any difference when I swap switches.
Does anyone have a reasonably priced motor assembly that works, preferably in the Atlanta area? Hopefully there are a bunch out there from all of those stripped race cars!
Thanks in advance,
Richard
Thanks in advance,
Richard
I fixed my original window motor by stripping it down to armature and carbon brushes, testing continuity and then cleaning and lubricating everything. Once reassembled, it worked immediately and after running for several seconds, it got even stronger and smoother.
Maybe I need to go through the drive through window more often!
Thanks to Dan for his kind offer, but I no longer need the motor.
