Boost bleed off issue
Rundown. 88 Turbo S, 42k on the clock, just installed Vitesse DME Chip, 3 bar fpr, black **** MBC, and Tial 38mm wastegate. When first installed, I was set at 17 psi and holding till redline. 1k miles later boost is now dropping down to about 13 ish psi by redline. I took off the DV valve and tried blowing air through it but couldn't get it to leak at all, so I don't think it's the DV valve, at least not yet. Any pointers?
Just replaced the DV valve with a Forge unit. It has the green spring in it which is rated for 6-8 psi. Still losing boost, bleeds off to about 10 psi at towards redline. Full boost is set to 16-17 psi. Should I try a higher rated spring in the DV valve?
Have you tried to re-adjust your MBC?
You either have a dead MBC, bad WG, or boost leak... ON boost the DV either holds or doesn't, but it shouldn't be causing bleed off from peak boost... even if it were bad.
I put in a stronger spring (yellow) and now only boosting to 10psi without touching the manual boost controller.
I am going to turn up the boost controller to get back to 16-17psi and see if it holds.
All the vacuum lines look good. Idling I am getting -20 pounds of vacuum. In gear coasting about -25pounds of vacuum. Wastegate is a Tial and is brand new. The lines I ran to it from the boost controller I have put hose clamps on. Zip tied the rest of the lines I ran for the MBC/Wastegate setup in the engine bay.
No oil drips under the car if left parked for a while. It's pretty dry. The back of the head does have some very slight seepage. It's been pretty good about not burning any oil either. I only have to top it off so far every 1k miles. It goes from full to about 3/4 on the dipstick.
The MBC responds accordingly. The Tial wastegate is brand new so hopefully not that. I didn't hear any kind of exhaust leaks after I finished putting everything together.
Right now, it is making 10 psi and holding until redline. I didn't have a chance to drive it after I turned the MBC up a bit to get back to ~17psi. Will post later after my drive home, hopefully not to much traffic.
cranked the MBC up a bit, but didn't really make a difference with the yellow spring in the DV. Put the Green spring back in and I am back to spiking 17 but dropping down to 10 psi by redline.
I looked over all the vacuum line fittings and all the rubber fittings look to be in good shape. No cracking on the rubber boots, are there any fittings/lines that are not easily visible poking around the engine bay that I may have missed? Someone mentioned the AOS, but I am not leaking any oil and the motor is barely burning any up. Thanks all for your help!
Drive-by provocation guy
Well, it seems the more you mess with the DV and or the hoses in, out and around the DV is what is causing differences. So I would look in and around the DV for your problem.
The leak is small, or what ever is leaking, is holding 17psi for a bit and then the leak opens up and then bleeds boost off. 10-12 psi peak is usually the sign of a small crack or cut in a boost line.
Many leaks you will not see, only hear with a pressure test or with soapy water to look for bubbles and also can be a split in a hose under a hose clamp.
