looking for some parts and some advice on LR fuel lines
First off,
-I am looking for a good power steering pulley. The one that goes on the crank.
- the black dash piece that surrounds they key hole.
-an '86 sunroof motor assembly.
-a section of a turbo wiring harness. I need a foot of the wires that go to the front turn signals and the plugs so I can convert my 944S harness for a turbo front bumper. It is a three wire plug.
for the needed advice. I bought LR SS fuel lines form 944S motor. Both of the connections are screw on fittings and I need one to be a clamp on for the fuel return. I need it to be like a 951's fuel lines where the front side is a screw on fitting and the other line goes to the fpr and is a clamp on. Any Advice on maybe just just cutting the hose past the screw on fitting part and just clamping it.
thanks,
Dillon
thanks,
Dillon
you can possibly put a hydraulic tube fitting on the tube where your planning to clamp on .
throw a photo up of the connection your trying to make and we will be able to advice a little better .
perhaps there is another FPR with a screw on fitting
Give Dave Lindsey a call tomorrow and ask him. He'll be able to tell you what to do that WON'T set your car on fire. And trust me from experience, you don't want that.
