Why is there too much pressure in my crankcase?
After changing my AOS housing because it cracked after installing a Souki Michi catch can, and lindsey venturi delete, I still have pressure in the crankcase blowing oil out the top of the AOS and oil fill tube. Why is this happening? There was a vent thingy in the venturi line that attaches to the top of the AOS, but after asking the advice of listers that had the same catch can, I deleted it. I should note, I am boosting it hard at 17 psi testing....... I threw the dam thing away too, so I cant just go and reinstall it. Anybody with a catch can, on thier race car please, I'd like to hear your input.
A catch can will not prevent crank case pressurization (as it sounds like you were dealing with a pressure problem before the catch can install). Any idea what condition the rings/bores are in?
