This is odd...
Old 04-01-2010 | 02:16 PM
Adam Poland's Avatar
Adam Poland
Default This is odd...
Ok, so were having a few problems with the racecar. It will not start without you putting your foot in it just a little bit, and when it does start it spits and sputters. Now this is the weird part....the car will run with the fuel pump switch off? Once the car is running, and you turn it on, the car dies. Completely dies, no sputtering. Our ignition wires were fried, and the ign. switch is right next to the fuel pump switch, so i figured those wires could have fried the fuel pump wires, but they didnt. Also, whenever i removed the fuel rail to see what the injector spray was like, all of them were shooting a stream, not a fine mist. Could this be from my Power Perfect, or could the injector wires be fried, since we fried a DME a while back? The injector wires appear to be good by the injectors, however, I have not cut them open and really done a thorough check yet. Any help would be appreciated.
Quick Reply: This is odd...
