SFR Headers Stage2, Tial 46mm + Lindsey 3" = Problems?
Old 03-26-2010 | 05:49 AM
Wishmaster's Avatar
Wishmaster
Default SFR Headers Stage2, Tial 46mm + Lindsey 3" = Problems?
Hi,
i tried to install my new SFR Headers with the Tial 46mm Wastegate and adaptor kit. It fits good.
I installed the Wastegatevent to the crosspipe and the vac.hose to the sideport of it. Hope this was right?
Now i have to install the adaptorpipe to the Lindsey 3" Exhaust but it won't fit. Look at the picture. Where is my problem? I think i have to weld me a new pipe from Wastegate to the Lindsey Exhaust.
Perhaps you have any idea whats wrong there?
Sorry fpr my bad english
Cheers,
Sven
Old 03-26-2010 | 06:48 AM
Techno Duck's Avatar
Techno Duck
Sven, sorry but i cant help with your problem. I however was wondering if you had any tips for installing the headers? Did you loosen the motor mount and jack up the right side of the engine?
Old 03-26-2010 | 08:21 AM
951Saga's Avatar
951Saga
Hi Sven, please take a picture to show your complete Lindsey system so we know which version you have.
Old 03-26-2010 | 10:11 AM
Duke's Avatar
Duke
Can you rotate/adjust the pipe between the wastegate and the crossover?
Old 03-26-2010 | 03:46 PM
Wishmaster's Avatar
Wishmaster
It was a big job to install the headers. The old bolts on the turboside are very bad. I only removed the Stuts on the header side because the sfr header is to big.
the headers...
Lindsey 3"
all complete...
I put the adaptorpipe in the lindseyexhaust and it won't fit to my tialwastegate..
Yes, i can. It's all new. Bolts, seal, pipe.
Old 03-26-2010 | 03:59 PM
The DareDevil's Avatar
The DareDevil
I ran into the same issue as you. I had to significantly shorten the wastegate-to-exhaust pipe in order for it to fit with the Lindsey 3" system.
Old 03-26-2010 | 04:10 PM
Wishmaster's Avatar
Wishmaster
I think that is have to shorten the adaptorpipe to exhaust and weld it in another angel. But its good to hear that you had the same problem...
Old 03-26-2010 | 04:24 PM
ramius665's Avatar
ramius665
That is one of the most highly polished cam towers I've ever seen.
Old 03-26-2010 | 04:36 PM
Bri Bro's Avatar
Bri Bro
I would be contacting Lindsey and ask them why it doesn't fit before you start modifying it. They have sold quite a few exhaust systems and should have a solution to your problem.
I was able to bolt up the SFR headers without jacking up the engine but it was a very tight fit. You need to remove the hard water line and I alos took off a few more parts to allow a little more room.
Old 03-26-2010 | 04:37 PM
Wishmaster's Avatar
Wishmaster
Yeah it's not only polished. cleaned, polishes,cleaned, chromed, cleaned, ant the porsche letters are real gold
Old 03-26-2010 | 05:12 PM
Mike Lindsey's Avatar
Mike Lindsey
Basic Sponsor
Our exhausts wastegate receiver pipe have been identical since day one in centerline. We have adjusted
diameter a little back and forth over time. The wastegate pipe to exhaust may need shortening. They
vary in length. Size and cut as required. Or better yet, trim some, test fit, trim more if
need be.
Chrome is a dipping process through many steps. How did they protect the lifter bores, cam
bores and what about flaking of chrome inside if they didn't get good adhesion?
Mike or Dave Lindsey
www.lindseyracing.com
U.S. 1-877-943-3565
Other 1-405-947-0137
Old 03-27-2010 | 11:10 AM
Wishmaster's Avatar
Wishmaster
The adaptorpipe is wrong in angel and size. I think i weld me a new pipe and than it's good.
All holes have to been closed with spezial plugs and plates additionally all other things are mask with spezial tape. I also chromed the Lindsey intake coolant and pipes... A friend of me chromed his shortblock, head, gearbox of a vw golf
Old 03-27-2010 | 04:41 PM
Adonay's Avatar
Adonay
Your car will be awesome ! Are you happy with your oilcooler and FMIC ? Have the FMIC but not yet installed.
Old 03-28-2010 | 05:51 AM
Wishmaster's Avatar
Wishmaster
I installed it but i haven't attached the oilcooler. SFR sent me wrong fittings. So i have to buy me new ones.
What do you mean with FMIC?
Old 03-28-2010 | 07:39 AM
Korenwolf's Avatar
Korenwolf
Originally Posted by Wishmaster
I installed it but i haven't attached the oil cooler. SFR sent me wrong fittings. So i have to buy me new ones.
FMIC = Front Mounted Inter Cooler.
Is your avatar picture an actual picture of your car? Because that car has the intercooler moved down, requiring longer intercooler pipes, this allows the oil cooler to be fitted where the factory intercooler normally sits. All of those in the picture look like SFR items...
I think people (well I am) are curious if the extra length of intercooler tubing adds any noticeable amount of extra turbo lag to the system.
Also, why did the fittings not work with your car? German model? Or...?
Quick Reply: SFR Headers Stage2, Tial 46mm + Lindsey 3" = Problems?
