Finally mounted new oil cooler (pics)
hopefully it will cool better than stock. Now that is all mounted I will have a lister make a nicer bracket.
That's where mine is mounted as well, it looks to be the same size too. The only difference being, I have the ports facing to the passengers side, so the mounting is a little different.
Do you have the upper radiator inlet shroud, in place?
yes i do. I have an extra if you need it
