K26#8 turbine inlet diameter?
Just curious. Does anyone know the turbine inlet diameter of a KKK #8 (or #6, they are probably the same on the inlet side)?
Do you mean turbine "8 housing is bigger but turbine wing is the same as #6? I don't see any advantage just to make turbine housing bigger but leave turbine wing untouched. I suppose i have to measure #6 & #8 wings to see if they are the same.
yeh my under standiing is the 6 or 8 represents the AR ratio wich represents the size of the nossle that curves around and the discharge size as the gas hits the blades so a 6 is smaller and will have the gas hit with greater velocity for a given CFM BUT it genraly chokes the exhaust to much and the increase in exhuast manifold pressure offsets the possibly quicker spooling turbo ...
there is still a massive lack of direct comparisons ...
I still say Porsche considered #6 to small for a 250 hp engine why would any one want one
Only the turbine exit is different. The #6 hotside also has a "flat spot" on it just above the turbine INLET. Clarks garage has a page on how to identify the two turbos.
K26-6 specifications:
Compressor Wheel: large OD:2.60; small OD: 1.74, depth: .87; small OD Clearance: .04
Compressor Housing: Exit ID: 1.63, Exit OD: 1.96; Intake ID: 1.78, Intake OD: 2.01; R: 2.0
Turbine Wheel: large OD: 2.54; small OD: 1.91, depth: .92; small OD Clearance: .06
Shaft: OD ~10mm; Thread: M6
Turbine Housing: Intake ID: 1.88; Intake bolt rectangle 3.00 x 1.50; Exit ID: 1.97; Exit bolt square: 2.50, R: 2.5
K26-8 specifications
Compressor Wheel: large OD: 2.60; small OD: 1.82, depth: .85; small OD Clearance: .04
Compressor Housing: Exit ID: 1.63, Exit OD: 1.96; Intake ID: 1.85, Intake OD: 2.00`; R: 2.0
Turbine Wheel: large OD: 2.54; small OD: 2.15, depth: .93; small OD Clearance: .06
Shaft (same as K26-6)
Turbine Housing: Intake ID: 1.88; Intake bolt rectangle 3.00 x 1.50; Exit ID: 2.21; Exit bolt square: 2.50, R: 2.5
