EGT Monitor
Old 03-13-2010, 04:39 AM
951Doc
951Doc's Avatar
Default EGT Monitor
I have yet to find an inexpensive 4-probe EGT monitor/display in the automotive world, but MGL Avionics has a 2.25" round display that will handle up to 4 thermocouples (K-type compatible) for $225. Chief Aircraft has them, see the link for the MGL-TC1 unit:
http://www.chiefaircraft.com/airsec/...ingles.html#tc
...just thought someone might find this useful. If there are better alternatives in the automotive world, I'd like to find out about them.
Cheers
________
1986 951
1987 951 project
www.project944turbo.com
Old 03-13-2010, 05:01 AM
gt37vgt
gt37vgt's Avatar
yeh this little box is about 260 US and it logs 4 thermocouples the amnps in there
logs 3 X 0-5v inputs
2 pulse or rpm inputs
and conrols and logs wide band o2
so it's you can easy configure it to log MAP RPM injector duty air inlet temp
http://wbo2.com/3a1/default.htm
Old 03-13-2010, 05:06 AM
A.Wayne
Formula One Spin Doctor
A.Wayne's Avatar
Interesting ... have you used one yet ?
Old 03-13-2010, 09:42 AM
Chris White
Rennlist Small
Business Sponsor
Chris White's Avatar
Here is another link (same price) for the MGL 2.5” gauge - http://www.aircraftspruce.com/catalo...es/1105719.php
they also make a 3.5” version for $240 http://www.aircraftspruce.com/catalo...es/1105698.php
For those that like to fabricate stuff aircraft spruce is a great resource…really neat stuff at a reasonable price.
For those that have not been to Aircraft Spruce before – I am sorry that I just pointed out another place that will make you spend more money…
http://www.aircraftspruce.com/menus/cm/index.html
http://www.aircraftspruce.com/menus/me/index.html
Old 03-13-2010, 10:00 AM
Chris White
Rennlist Small
Business Sponsor
I have race technologies dash in the track car and the only other Gauges is the 3.5” MGL E1 and a boost gauge.
The dash is begin redone for this season…I am looking forward to the digital world!
Old 03-13-2010, 10:32 AM
951Doc
951Doc's Avatar
I haven't used the MGL, but I do have a JP Instruments EDM 700 CHT/EGT bar graph on my certificated aircraft (MGL is for experimental aircraft). These units are very easy to wire up and the bar graph gives a quick picture of the mixture distribution amongst cylinders.
Old 03-13-2010, 04:59 PM
Techno Duck
Techno Duck's Avatar
Very nice, i was looking at the Aerospace Logic some time ago before i decided to just get a Defi single channel gauge.. didnt really need the 4 channel, especially at ~$400 (plus cost of four probes) for the Aerospace Logic. This is much more reasonable though and a nicer looking gauge. Still have yet to order the rest of the gauges, but i think i may try one of these out.
Old 03-13-2010, 05:07 PM
theedge
theedge's Avatar
Ive been thinking of the MGL too. The only downside to it is that it stores the high values in memory and cant be erased/reset. So theres no reset button to get highest EGTs for the session/drive/etc.
Edit: And its bezel with the screw holes isnt removable. I asked.
Old 03-13-2010, 08:22 PM
Chris White
Rennlist Small
Business Sponsor
When viewing the memory temps pressing the F1 key will reset the value.
You can always ‘trim’ the bezel and then rear mount it with a 58mm round hole.
Old 03-13-2010, 09:13 PM
Bri Bro
Bri Bro's Avatar
I wanted a single channel (using the test port) that I could datalog. Went with AEM analog gauge, has a 0-5V output. At $170, it isn't too bad.
Chris, Aircraft Spruce is a great place to shop for really good products. I use them at work all the time. I like the fact that I don't have to write the check.
Old 03-14-2010, 08:18 AM
gt37vgt
gt37vgt's Avatar
the probes are not expensive its the fancy stainless braid that is expensive ..
you can by regular probes from the electronics shop for 12$ you just have to be careful mounting them
Old 03-14-2010, 11:17 AM
Chris White
Rennlist Small
Business Sponsor
My pet peeve on most of the automotive EGT gauges is that they stop at 1700 or 1800…you can see more than that on a 944 turbo….and that’s where you want to know what’s going on!
Old 03-14-2010, 01:47 PM
theedge
theedge's Avatar
What situations would you want to see more than 1800F? Isn't that too high anyway I mean...
Old 03-14-2010, 02:19 PM
Chris White
Rennlist Small
Business Sponsor
You don't 'want' too...but you may see it and it would be really nice not to look at a pegged gauge!!
Its kind of like having an oil pressure gauge that does not show anything below 20 psi. You don’t want to be there…but you sure want to know what’s going on it you do get there!
Old 03-14-2010, 04:15 PM
Bri Bro
Bri Bro's Avatar
I had to look around for one that went to 1800F, lots of them only go to 1600F. I do believe if I see my gauge pegged at 1800 for more then a few seconds, I am slowing down. Too much money in the headers and the turbo to "cook" them.
I have read that some have seen 2400F when the car starts to backfire but I think the noise would be a clue to back off.
Quick Reply: EGT Monitor
