Wheel Alignment question...
Old Mar 7, 2010 | 10:29 PM
LFA951's Avatar
LFA951
Default Wheel Alignment question...
I bought the car with cut springs and drove it stiff for over 3 years. I recently just bought stock springs, had them put on and the car's camber is off on both sides and pulling to the left. Can these cars be aligned with the camber or are they just toe?
Old Mar 7, 2010 | 10:36 PM
ritzblitz's Avatar
ritzblitz
Yes, camber adjustment is built into the strut/spindle. It is the top strut bolt.
Old Mar 7, 2010 | 10:54 PM
LFA951's Avatar
LFA951
Thanks, that's what I thought, I took it to an alignment guy at a privately owned tire place and he said you could only adjust the toe, I thought to my self he was full of it and that he probably didn't know how to do it...
Old Mar 8, 2010 | 10:31 AM
Van's Avatar
Van
Not only is he full of sh|t, but you can also adjust the toe and camber of the rear wheels...
Old Mar 8, 2010 | 06:29 PM
LFA951's Avatar
LFA951
Awesome, I am taking it to a guy who is familiar with 944 turbos, he charges $59.99 for the front....
Old Mar 8, 2010 | 06:52 PM
rlm328's Avatar
rlm328
Don't just get the fronts done. You should have all 4 wheels aligned at the same time with the rears being the major PITA. The alignment interacts some what from what I have been told.
Old Mar 8, 2010 | 09:45 PM
LFA951's Avatar
LFA951
The rears wear out a little more on the outside, I'll have him check them as well, thanks for the suggestion....
Old Mar 9, 2010 | 07:26 PM
schip43's Avatar
schip43
You need an Eccentric Adjuster to set the toe on the rear of the 944. You can but on line and take it to him of he doesn't already have one. If he doesn't know what that is go elsewhere!
10 Best Cars of Lake Placid Porsche Parade
Porsche Celebrates 75 Years in the UK With Special Manual 911 GT3
Porsche Taycan Gets 'Engaging' Updates For 2027: 9 Things to Know
7 Porsche Models That Have Aged Like Fine Wine
Old Mar 9, 2010 | 11:59 PM
TonyG's Avatar
TonyG
Rennlist Junkie Forever
No you don't. A wood block and a 5lbs sledge hammer work fine.
In fact, if you have a track alignment with a lot of negative camber, the eccentric tool will only take out toe, but is out of range to add toe. Thus if you adjust your toe out too far you're SOL.
After you've aligned the rear of these cars over and over, you just set your camber, then set the toe wtih the wood block and hammer.
I can align the back of the car in about 20 min after the initial setup and roll out.
TonyG
Old Mar 10, 2010 | 04:59 PM
schip43's Avatar
schip43
"After you've aligned the rear of these cars over and over, you just set your camber, then set the toe wtih the wood block and hammer.
TonyG"
Well that's pretty impressive and I don't doubt "you can do it!" But if I am paying to have an alignment done the tech had better not come at my car with a block of wood and a sledge hammer!
Old Mar 10, 2010 | 06:42 PM
TonyG's Avatar
TonyG
That's about the only way to do it if you havew a track alignment (unless you modify the adjustment holes or perhaps get a different eccentric bolt).
TonyG
TonyG"
Old Mar 10, 2010 | 06:58 PM
schip43's Avatar
schip43
Not doubting you at all! Just sounds kinda wild! I run more camber front and rear street for now. I did a lot of research on toe and decided for me I keep the toe to factory specs.
Saw something about too much toe inducing snap over steer! I'll pass on that! Don't want to change what I don't understand so I maxed caster and added camber (camber plates db Adj Koni's MO30 Turbos S running staggered 17's,New MO30 Sway bars)
Old Mar 11, 2010 | 02:25 AM
TonyG's Avatar
TonyG
Toe in doesn't induce over steer. Quite the opposite. On a race track the only negative to toe in is drag and slowing the turn in.
Factory specs are fine for a street car but are no where near what's needed for a race track.
TonyG
Old Mar 11, 2010 | 02:40 AM
944CS's Avatar
944CS
tony are you saying you run a lot of toe-in in the back?
Old Mar 11, 2010 | 10:42 AM
TonyG's Avatar
TonyG
-.10 to -.15
TonyG
Slideshow: The 10 Porsches I couldn't stop thinking about at Parade 2026
By Joe Kucinski | 2026-06-22 10:28:13
Slideshow: Limited to 51 examples, the Earls Court 51 Edition pays tribute to the first Porsche displayed in Britain back in 1951.
By Verdad Gallardo | 2026-06-19 18:37:27
Slideshow: Porsche's hoping to liven Taycan sales up with simulated driver engagement!
By Verdad Gallardo | 2026-06-17 14:36:56
Slideshow: Some Porsches have become icons with age, proving that great design doesn't follow trends or expiration dates.
By Verdad Gallardo | 2026-06-16 13:40:23
